- Thread starter
- #41
Hey guys, would this Moly grease work?
How are the splines on the axle?
Davegonz,
Check out his small vid a few posts above. The axle splines are worn right down from the looks of it.
ClassicYotas, you may want to invest in a new axle while you're at it. This project is about to get a bit pricey. Hopefully the other side isn't like this. Good thing is that you can just get the birfield end and not have to buy a whole axle assembly.
Birfield Joints
AXTBIRF-FJ80HD
You'll need the stronger drive flanges to go with Nitro: TOY43421-60040
Toyota OEM birf ends are Super Pricey but available as well:
1990/01 - 1992/08: 43405-60030 FJ80,HDJ81,HZJ81
1992/08 - 1994/04: 43405-60050 FZJ80,HDJ81,HZJ81 L=238.5
1992/08 - 1994/04: 43405-60060 FZJ80,HDJ81,HZJ81..GX,VX,VXL アリ(*66), L=238.5
1994/04 - 1996/08: 43405-60070 FZJ80,HDJ81,HZJ81 アリ(*66), L=246.5
1994/04 - 1996/08: 43405-60080 FZJ80,HDJ81,HZJ81 L=246.5
His flanges are very worn and the spindles will need to be replaced if he can't clean them completely.If you don't want the old flanges, I'll take them. I want to see if they'll fit my 100. I've always wanted a set with worn/no splines to use for a broken CV field repair.
The 100 stud diameter and pattern is different fwiw
@aljollano came by to help. He said everything else looked fine what what he saw. But I will post up pictures to confirm.
I already bought flanges from @cruiseroutfit. The normal stock ones. So I would need to buy Part# FAXTBIRFFJ80 from Cruiser Outfitters
Eeek!
Definitely time for new birfs, new spindles, and new inner axle seal. They are all toast.
I wouldn't even keep the birfs as trail spares in that state.
I'd strongly suggest using post '94 birf and drive flanges.
