I’ve searched this topic extensively and I think I got it, but would appreciate anyone who has done this before chiming in and letting me know if I have it right.
I got a rebuilt diff from cruiser outfitters 2 years ago, and put it in but didn’t open the clogged breather. Many ups and downs over 11k’ passes and it is leaking from the pinion seal.
I saw in another thread that there are two types of diff spacers, crush sleeves for the newer diffs and bearing spacer tubes for the older ones like mine. FSM says to replace the bearing spacer, but to do so you have to pull a bearing and a race.
My question relates to the proper way to Retorque the pinion nut for a diff with a reused bearing spacer.
It seems to me that it should be retorqued to spec torque as the bearing spacer tube is not a crush sleeve. Is this correct?
Or should I measure the torque required to loosen it and match that?
Any experiences are welcomed. TIA
