91 FJ80 Engine in a 95FZJ80
I am sure this has been posted before.
Will a 91 engine, transmission, etc fit into a 95FZJ80?
I have a 91 with a working engine, that was crushed by a tree and a 95 that has had engine issues and would like to get it moving again.
Thanks in advance for the help.
Stephen
I'm sure it COULD be done, but way too much work and trouble. Most 95s are OBDII compliant. ECU, wiring, smog, sensors, etc all different. Different driveshaft length due to no CDL on 91.
It's been talked about before- way too much work to do. If the 95 engine is blown, just get a replacement 1fz
Not sure of your location, but some states with strong emission control regs may not allow you to go backwards like that, so that may also need to be checked for your situation.
