Hi all, I have been trying to diagnose a rough idle on my 91 3fe and am running out of ideas. The truck has 185k and is desmoged. Symptoms: the truck starts right up and runs mildly rough at 1200rpm then settles normally down and stays at 650 where it has a very pronounced irregular miss/rumble. Somtimes it is enough to shake the truck but the idle never really gets down below 600. No hesitation, no stalling and revs and accelerates with full power. After it is warm the miss is imperceptible Above 800rpm. Felt like a vacum leak so thats where i went first, methodicly propaned the engine bay with no change in idle. Next i hooked up the vacuum gauge and its steady at 21in at startup and 20.5 with slight, slow .5 wander at 650rpm. That ruled out a major intake leak but i did a smoke test just to make sure. No vacuum leaks. From there i have tried to work through all the systems without being able to fix the problem. Here is what i have done so far.
Electrical:charging system tests good. Coil and Ignitor swaped with known good ones. New plug wires distributor cap rotor and pickup coils with air gap set per fsm. Plugs oem gaped .043. Power balance test drops cylinders evenly, and inline spark tester shows good spark at each plug. I also opened the wiring harness from the fire wall all the way to the injectors without finding any burnt wires. Also new o2 sensors. New water temp sensor.
Fuel: new sockfilter, new fuel pump, new inline filter, new pulsation damper, injectors replaced With a used set that were cleaned and balanced, new fpr. Pressure tests at 37psi and 45 return line clamped.
Air: new filter, afm pulled and bench tested per fsm. Srews never taken out But pulled the black cover and checked the solders anyway. New marine fuel line to replace the accordion section Intake hose. Throttle body cleaned tps tested and swaped with known good one. Iac bench tested per fsm and cleaned.
Mechanical: valves adjusted And checked hot three times durring all this. New valve cover gasket pcv valve and bolt grommets. Compression test number are: 160 155 154 158 155 154. I did a leak down test at 100psi, and i dont know If i trust it because i got between 5 and 10% on all cylinders Which seems way to good for that many miles. And i did Think i could hear some leaking at the tail pipe and a small amout From the dipstick but nothing rushing out. Also wouldnt a bad valve be real evident on the vacuum gauge? And poor compression? I havent done anything to test the ecu but how often Does that go bad? The truck haD always been garaged and never In extreme conditions Before i got it. Hope some one can point out somthing ive missed, i hoped to not take it to a shop ever but I'll have to fire myself pretty soon if i cant lick this. Thanks for any input.
