86 fj 60 ok the rear heater fan is not operating . when the blower motor is tested to a 12 vdc battery it spins fine , internal inspection looks good , relubed bearings and the brushes look good. when the heater is plugged into the rear heater load leads (read; plug ) the blower does not spin . when monitoring the voltage on the blower plug leads there is 12v when the motor is not connected. when the motor is connected the voltage is les than 1 vdc . which leads me to beleive that the control contacts in the rear blower switch or relay are bad . My question is .... Is there a control relay for the rear heater or is it controled directly throught rear heater switch. any help or references to the factory wiring schematic would be appreciated. Augie
