- Location
- United States
**SOLD**
This will eventually be posted on CL and Autotrader but giving folks here first shot at it. This is one of the best vehicles I've owned but now I need a full size truck.
1989 TOYOTA PICKUP, XTRA CAB, 4WD, 3.0L V6, AUTO TRANS, AC, 148,030 MILES
$3,900
The truck is low mileage, clean and well maintained. It has been adult owned and driven. It's a survivor. The engine, suspension and drive train are in unmodified, stock condition. No dogs and no smoking so the interior is clean and in fine condition. This truck could be used as-is or as a great starting point for a restoration.
Current New Mexico registration and the title is clean, clear and in my name.
Engine runs great. It uses no more than one quart of oil in 3,000 miles. Recently got 20.2 MPG on a round trip from Raton NM to Pueblo CO. Gets 14 MPG around town.
No leaks except for a power steering fluid drip – I believe it is a hose.
Transmission operates as it should. Positive shifts and no slipping.
Transfer case and manual hubs operate as they should.
Tires are General Grabber AT2 all terrain, LT235-85-R15 with 75% tread and in excellent condition. There are two mounted spares in excellent condition.
All gauges, accessories, switches and lights operate. Exception is the dome light.
No body rust and the original paint shines. This truck turns heads.
Frame is solid and most of the original paint is still on it.
AC converted to R134 and is ice cold.
Have a 1/2” folder with maintenance receipts going back to 1996.
Owners manual, factory jack and a partial factory tool roll included.
Comes with ARE aluminum camper shell with contractor doors and screenedsliding windows. EDIT: screened windows are tilt out.
Known Defects:
Slight leak from power steering hose.
Could use new front rotors.
Radio antenna base loose. Radio powers up but no reception.
Dome light does not work.
Dent in right rear corner under tail light.
Older paint touch-up on tailgate.
Front valence has some wrinkles.
A few scratches and dings.
Slight upholstery wear on outside of drivers seat.
Dash has one crack.
Dash bezel modified to install aftermarket radio.
Non-original features:
Has later vintage Tacoma steel wheels.
Rear bumper is an aftermarket replacement.
Blaupunkt AM/FM/Cassette in dash radio and aftermarket speakers in rear.
12V power point added to center console.
Under bed spare tire carrier was removed.
I have many more photos.
EDIT: Link to Imgur photo album: '89 Toyota Truck
$3,900
Known Defects:
Dash has one crack.
