89 Full Size Blazer Power Steering
Discussion in 'GM/Chevrolet' started by hank14, Feb 25, 2007.
  1. hank14
    hank14
    2,441
    Media:
    1
    91
    Nov 26, 2004
    Texas
    Pulling Power Steering Pulley- Chevy Full Size Blazer
    I'm trying to remove the pulley from my PS pump. I bought a cheap $20.00 pulley puller from Autozone, and proceeded to mangle the end of the pulley that the puller attaches to. I have used PB Blaster for 2 days. Any secrets to this?
  2. RVBtruck
    RVBtruck
    210
    Jun 19, 2006
    Neenah, WI
    Try some heat, use the ole torch to get her hot. I'll ruin the pump seal tho so I hope you're replacing it or the pump.
  3. hank14
    hank14
    2,441
    Media:
    1
    91
    Nov 26, 2004
    Texas
    Yep- the reason I'm pulling it is to replace the pump seals. The pump is working great, but it has been leaky for a while. I am also thinking about either gringing the puller so it fits better, or looking for a 3-pronged puller.
    Thanks.
  4. cam75w/ls1
    cam75w/ls1
    258
    1
    Jan 23, 2007
    Texas, of course.
    Those things are pressed in tight! If the lip is too messed up for the tool to get ahold of it then it's almost hopeless. What ever you do,don't hammer the pulley back on because that the fastest way to ruin a Saginaw pump.
  5. hank14
    hank14
    2,441
    Media:
    1
    91
    Nov 26, 2004
    Texas
    So far I've resited the urge to bring out the heavy equipment- hammers, vice grips, etc. I haven't looked at it since Sunday.
  6. hank14
    hank14
    2,441
    Media:
    1
    91
    Nov 26, 2004
    Texas
    Update-
    I went back to Autozone and found someone who had actually removed a PS pulley before. He said I bought the wrong one (the cheapo) and needed the rental variety. Once I used it, it came of with only some general groaning. Replaced the seals and both hoses, and I think it's good to go.
    I raised the front on jack stands and bled the system- it's whisper quiet and easy to steer as before. Glad to have this project finished.
