'89 Fj62 Towing 4200lb Airstream
BOZEMAN, MT
:confused: I JUST GOT A '89 L/C WITH 240K ON IT AND ALSO BOUGHT A 27' AIRSTREAM OVERLANDER. I INTEND TO CONQUER THE WORLD WITH THIS SETUP BUT I NEED SOME HELP. tHE L/C DRIVES NICELY, BRAKES STRAIGHT AND APPEARS TO HAVE GOOD POWER AND DOES NOT LEAK OIL ETC... THE AIRSTREAM WEIGHS IN AT 4200LBS. I WAS PLANNING ON BEEFING UP THE REAR SUSPENSION ON THE L/C WITH THE AIR-BAGS, ANTI-SWAY AND GETTING TONGUE WT DOWN WITH TRANSFER HITCH. WILL THE TRANNY AND ENGINE, BRAKES ETC. TAKE THE HEAT???
-LOS
Caps lock broken?
You will be over-weighted I think. I'd find a beffier pull rig, or smaller trailer.
The L/c Is Built Like A Tractor Right? I Mean It Weighs 5600lbs Or Something And Has Got A Small Engine For Its Size But Will I Kill It? I Was Planning On The Survival Of The Fittest Philosophy Here. Drive It Till It Drops And Then Put A V8 In It. I Dont Want To Torch The Rest Of The Vehicle Too Though.
The L/c Is Rated At 3500lbs So Technically It Is Overweighted. But Is It Necessary To Drop Another Engine In It? I Do A Lot Of 4 Wheelin Around Here And Want To Keep The Truck. What Do You Mean By 'caps Lock Broken'? The Locking Differential Works If That Is What You Mean...
An FJ62 is rated to tow 3,500 pounds, that's correct. Can it do it efficiently? Not a chance. But if you insist on doing this (while the rest of the world flies by you on the left) be sure to mount an oversized/external transmission cooler. You're going to need it. Oh, one more thing, you'll need to plan all your outtings with the 62 and the trailer so that you never encounter a hill.
TJK
Can it be done?? Hell yes!
I pulled a buddy's drag bike in a 24' enclosed trailer with my 60 on a three hour tour ;) .
we made it fine but top speed had to be around 60 m.p.h.
downhill...
with the wind behind me...
:cool:
No-body as even mentioned braking yet. Something else that comes along with being over-weighted is being under-braked. If you ask me, it's the more dangerous of the two. Over-weighted means you drive slow and are just annoying to people that want to go fast.
Being under-braked means you are a danger to anyone else on the road with you.
If you must pull that weight, upgrade the brakes before the engine.
PS, lots of people pull trailers with the 62's, just not that heavy.
cholznag said:
I see... So then if I were to beef up just about everything to do the job (from the brakes to the engine) I might as well have bought a Suburban?
Los-
To tow 4200lbs? Yes. To wheel? No. Cruisers are great vehicles but not for towing heavy loads.
Pop up campers definitely have their place. The grandpa mobile is mainly for visitors when they come into town although I will take it to Oregon and B.C. this year. The trailer is insulated and does pretty well when it is 20 below. How cold does it get in N.C.?
-Los
