Hello!!
Finally getting around to working on my newly acquired ‘89 FJ62!!!
First thing-hood latch mechanism-it all works but after a few closings it gets hard to final latch to the point where I’m denting the hood trying to push it into “lock” position. If I grab the bottom of the latch and bend it outward, thus raising the mechanism a bit, it will lock properly.
If I adjust the rubber stoppers on each side downward until I don’t have to do the above fix, it locks but the hood rattles-I’m assuming there’s supposed to be done tension in the closed position between the hold down and the stoppers to prevent rattling.
If I adjust the stoppers to stop the rattling, eventually it won’t lock after a few openings.
One thing I noticed is there is a threaded hole on the bottom most forward portion of the latching mechanism-is there some sort of strut that is supposed to attach to this and go down (or across) somewhere to support the front if the latch and prevent it from bending down? Attached is a pic.
Thoughts?
Thx
Bri
Thoughts?
Thx
Bri
