Hey,
The title about says it all. Stock 62, stock AC. Still R-12. Blows pretty cold for an old truck. I have replaced the blower before and the resistor before. I have the FSM. I realize there is an AC fuse (good) and a heater breaker (not a blown breaker) Fuse and breaker are behind the fuse panel.
So I have no power to the fan and the AC button doesn't light up like it did.
I also realize there are two relays and an amplifier.
Before it went out for good, some times when really hot, like after a quick stop and the heat soak had set in, the AC had no power as in nothing. I operated the switch back a forth a couple times and it would power up.
This is a DD truck. I like to shut down all electrical before killing the engine and bringing the systems back on again one at a time once fired back up. (like a pilot would in an airplane)
Battery is good, Alt is new Toyota Reman, Fuse-able links were rebuilt by a 40's forum member coolerman.
So i think I have a relay that has gone out.
With ignition on, and AC off, if I move the fan from off to low, there is a faint but definite click under the drivers footwell. I assume that would be one of the relays. I understand the AC system is a major electrical draw.
I need help identifying which relays are related to the system and how to check them if they are good or not.
I have power to all my other systems but I'm not saying a fusible link didn't fry, but which one do I look at?
My truck is at the shop and the FSM is there too. The guy just isn't getting to it so it's time for me to take control and fix it myself
Any help, much appreciated. It was 109 degrees in Oklahoma today. Tied an all time state record.
thanks,
thanks,
