For Sale 88fj62 parts (2 Viewers)
Do you have oem mudguards in good shape? I also need the chrome trim that goes on the rocker panels.
Thanks!!
Updated list:
Here is a brief list of some the parts I have for sale.
Drive Train:
Frt axel(complete) $350
Rear Axel $300
Drive shafts (frt and rear) $75 ea
Cooling Sytem Parts:
Radiator shroud-$35
waterpump with clutch fan with fan blade- $80
Engine parts:
mounts- engine- $60 Pair
Smog pump-$75
Air cleaner assembly-$30
a/c compressor $55
Motor Mounts-$50
waterpump with clutch fan with fan blade- $70
Air rail--$25
fuel injectors complete with fuel rail-$200
Intake manifold-$200
exhaust manifold-$80
engine block with pistons , crank shaft --$200
Transmission parts:
Shifter-transmission console with base plate-$40
Transmission mount-$30
Flywheel--$50
Torque converter-$150
Body Parts:
Frame $150
Hood-$150
Hood hinges-$30/pr
Hood balancers (springs)-$60/pr
glass for frt doors-$40
glass for rear doors(large)-$25
glass window cargo area-$35
Door -fuel filler(brown or gray) -$10 ea
Door Panels( interior brown or gray) -$25 ea
Motor-windows regulator-$100
Switch-power windows(no drivers dr)-$30
Glove box(interior box) -$15
Electrical parts:
Airflow sensor-$140
fan-engine cooling-$30
fan-defroster-$25
Do you have the driver door master window switch? Also I need a dome light cover if you gave one. Shipped to 89523
Fuse box door to 93513. Good working order, grey or brown ok.
John
Torque converter, have you checked its run-out? Thanks, MIke
Frt hood $150
air rail--$40
Fan engine cooling $40
Mounts motor--$50/pair
Mount for tranny--$75
shifter boots--$10 each
plates leave springs-$20 each
