I've been searching the posts and can't find what I need. I'm sure it's there somewhere so please bare with me.
I've got an '88 FJ62 with 290,xxx miles and the auto trans with OD. I had the filter and fluid changed about a month ago. For the last week or so, my tranny is slipping in 1st & 2nd pretty bad after warming up. When I shift it manually, I can feel the gears engaging like they should but I can't put it in D and just drive.
This is the 2nd transmission in this rig and the previous owner is the one who installed it. After searching online, I've seen where issues like this are caused by a defective transmission control module (TCM). It's a fairly cheap part but I don't know where it's located at. I have also adjusted the shifter cable leading to the throttle body and it made no difference.
So my question(s) is this, could a faulty TCM be causing my issues or is this transmission in need of a rebuild/replacement?
Should I have my transmission, which has small leaks, drained and back flushed?
Is there a particular type of ATF I should be using?
And yes, I have checked the fluid. Haha.
