87 FJ 60 Optima battery????
Discussion in '60-Series Wagons' started by sportbiker929, Jul 20, 2005.
  1. sportbiker929
    sportbiker929
    463
    Media:
    3
    52
    Jun 1, 2005
    Oakley, CA
    Which one do I need? My battery is dying.
  2. Cruiserdrew
    Cruiserdrew On the way there SILVER Star
    15,588
    4,639
    Mar 15, 2003
    Sacramento, CA
    Get the D34M from Costco. It's a blue top, works great.
  3. Pluton
    Pluton
    418
    1
    Oct 12, 2004
    They also make a D31A yellow series which is larger/higher cap but is slightly too large for the stock batt tray. That said, I've been using the standard group 34 red tops(with 1" blocks underneath)...no winches or heavy power drainers...the older of the two is almost 7 years old now...still fine.
  4. sportbiker929
    sportbiker929
    463
    Media:
    3
    52
    Jun 1, 2005
    Oakley, CA
    Sweet, the exchange has a D34M for 149.00. Thanks brother!
  5. HZJ60 Guy
    HZJ60 Guy Tank Buster
    2,356
    4
    Sep 11, 2003
    Seattle area
    Blue top Optimas are MARINE batteries bubbas.
    Get a yellow or red top.
  6. Cruiserdrew
    15,588
    4,639
    Mar 15, 2003
    Sacramento, CA
    Disagree Bubbita. Check the specs. Identical to yellow tops with improved vibration resistance. What's not to love?
    Besides, I have personal experience running blue tops in 2 Cruisers. Excellent performance.
  7. sportbiker929
    sportbiker929
    463
    Media:
    3
    52
    Jun 1, 2005
    Oakley, CA
    what is the difference
    dang you are fast
  8. hullendersauce
    hullendersauce
    414
    2
    Jun 4, 2003
    Westminster, CO
    red top!!!!
    Iggy and i were doin a tune up the other night, and noticed mine has been kickn since January '97. youknowthatsrice... -other sean
  9. Fearnofish!
    Fearnofish!
    260
    Jun 7, 2005
    Hamilton, MT
    yellow top will crank 700amps for 2 hours. Red top has higher initial amps (900) but wont crank nearly as long. Go yellow and never go back.
    IMO it's an expensive battery so why not order it from a vendor on the forum and pay a few dollars shipping rather than go to the chain stores. With gas what it is it's probably the same money.
  10. Mike S
    Mike S
    2,537
    18
    Aug 19, 2003
    I ran a single Optima YT D31A in the stock battery tray in my 60 before I went dual and swapped the stock trays for stainless. It fit fine, but I did need a modified holddown strap to accomodate the slightly higher top.
    These are incredible batteries.
    M
  11. dogboy2
    dogboy2
    996
    9
    Jul 8, 2004
    Portland, OR
    5 years and counting on a red top -- still going strong!
    -db-
  12. sportbiker929
    sportbiker929
    463
    Media:
    3
    52
    Jun 1, 2005
    Oakley, CA
    Well, I picked up a D34M for 140.00 on the base. Should be go to go now.
    Thanks for the input!!!
  13. polarweasel
    polarweasel Where's mah cruzah?
    991
    2
    May 6, 2004
    Vancouver Island, BC
    I'm going to resurrect this thread to pass on some information straight from Optima's customer service people...
    I emailed them asking what the difference was between a Yellow Top and a Blue Top. Here's what I got back:
    Straight from the horse's mouth, the only difference is warranty, due to anticipated use. I will definitely buy Blue Tops instead of Yellow Tops because the warranty is 50% longer! This doesn't change Drew's recommendation for the Blue Top, but it's good information to know anyway...
    Alex
  14. Landpimp
    Landpimp
    16,093
    Media:
    1
    2,082
    Mar 14, 2003
    Gig Harbor WA
    I recomend the Exide Orbital ever the Optima. I run a pair of the Extremes in my fj60, love em.
  15. hullendersauce
    hullendersauce
    414
    2
    Jun 4, 2003
    Westminster, CO
    whats the diff between the blue and the RED?? -=other sean
  16. gulp3000
    gulp3000
    569
    1
    Jul 21, 2004
    Colorado
    Red is for max cranking power - Blue and yellow are designed for use in situations where they get drained. Winching, lights, trolling motor. etc
  17. dd113
    dd113
    2,922
    7
    Jun 13, 2003
    I will NEVER own a red top again. I run Orbitals as the primary and Blue tops as 2nd batt. There is also a blue starting and blue deep. Check it for your application.
  18. Mace
    Mace rock scientist.. Staff Member s-Moderator
    21,701
    2,145
    Feb 17, 2002
    Las Vegas
    Exide is an optima. they are made in the same factory..
  19. polarweasel
    991
    2
    May 6, 2004
    Not exactly true... Blue is the MARINE designation. It means they've got SAE posts as well as stainless screw-on terminals. There's a blue-top starting battery and a blue-top deep-cycle battery.
    http://optimabatteries.com/ has all the details. Look in "Automotive" and "Marine" sections. Each has a technical specs link on the left side.
  20. hullendersauce
    hullendersauce
    414
    2
    Jun 4, 2003
    Westminster, CO
    so, the blue deep is what yall are runnin?
