86 Dieseling after shut down...
Berthoud Colorado
Website
www.w2m.com
What a drag.........Pull up to gas station as the entire place is fixed on your rig........you shut is off only to here a braaag bruuum buh uh glub clunk.........
How can I fix this deiseling after shut off...........bugs the hell out of me.
advance/Retard....... timming??
Can be a lot of things: carbon buildup in the cyls, a not fully closed throttle, bad gas. Check your idle cut solenoid and idle speed/misture.
Does it diesel regularly, or just that once? I once had a nicked oring in the nose of the fuel cut solenoid that caused a very pronounced "dieseling." Its easy to test the solenoid - just unplug it and see if the engine stalls. If the throttle is sticking, you'd likely have a rather high idle speed. What rpm are you idling at?
If I recall it has a Holly carb on it(2 F motor though), so its not gonna be the same as a Aisin., and I don't know poop abuot Holly's.
But yes timing to far advanced can cuase dsling, but the timing shouldn't have just changed by itself.
does it have a non US dizzy? to tell look for a little dial on the dizzy, that is the octane adjuster, if it has this it prolly still has points also.
I thought I read in TT that Cal had some fuel issues with the 60 on the ARB road trip.
It has nothing to do with timing, it's a fuel issue.
1) You can lower the idle speed as I explained to you already. :rolleyes:
2) You can install an idle solenoid. :idea:
3) You can use higher octane fuel. :eek:
4) You can leave it in gear and let the clutch out a bit as you shut it off. :doh:
Option four worked for me.
Cal
I love it...........leave the car in gear and kill it with the clutch...........yeah thats it ;) (and I have done it)
Sounds like time for a non US Aisin instead of the Holly.........prolly cure all kinds of stuff.
my 60 did similar.......turns out I had the vaccume advance hooked up to the carb so that it always had advance, once I got it back to the right port on the carb it was cured.
45 did similar, turns out on that it was a points or dizzy issue, once I swaped out the old dizzy and went to a fj60 dizzy it was cured.
whats up amigos, i bought my pig from the previous owner with the same problem.the p.o. pointed out some v.valve that needed to be rep. but at the time he may as well of been speaking swahili, the pig idled high at about 1000rpms and timing was off . why i didnt get it , anyways 3 years later timing has been adjusted carb rebuilt engine tuned and idle set ...but i still have the problem unless i use prem. unleaded fuel what gives!
Let the clutch out in gear take the load and kill the engine works every time.
Mine does this too.
Its a early warning system to tell me the plugs are getting fouled (300,000) time for a rebuild as I am burning a bit of oil and compressions down a little. Anyway if i pull the plugs and sand plast them they are ok for another 5000 or so. You can soon tell if they have a big buildup of carbon on them. (god knows what the exaust valves look like!!!!)
1. Lower idle speen..........nah more problems
2. install an idle solenoid...........don't know
3. Higher Octane Fuel.........................Bingo, cheap fix, drove it all day today with conoco premium..........no probs.
4. leave it in gear dump the clutch kill the engine.............surprised anyone would do this for extended periods of time.
thx cal..............Your a alright PO as they call em on the mud board.
Cal
I just worked a couple hours on my Cruiser over this same problem. The vacuum adv. was working fine, the timing was a little advanced, idling at 1100 rpms. I backed the timing off down to around 850 rpm on idle, and changed the plugs. The plugs wereSHOT. I've NEVER seen plugs as bad as these. I don't understand how it could have ran.
The carb had some carbon build up from the blow back? when it would diesel as well. Only problem I now have is two of the plug wires (#4 and #6) separated from the contact inside the wire and they'll miss occassionally.
CRUISERDAN fixed that issue, got a set coming for a KILLER price. Thanks Dan.
Any other thoughts on this?
You don't "dump the clutch" to kill the engine. With the e-brake on and the trans in gear you slowly let out the clutch just enough to slightly load the engine, THEN you turn the ignition off. It doesn't take much and IMO dosn't damage a thing. However your approach, allowing the engine to diesel and possibly reverse rotation, can be unfriendly to certain parts.
This shutdown technique is SOP with any high compression, high performance stick shift vehicle. If you want to be able to simply turn off the key you need an idle soleniod to shut of the supply of fuel or sufficient octane to prevent dieseling.
Cal
