- Joined
- Feb 15, 2006
- Threads
- 19
- Messages
- 39
I have a 86 desmogged 2f with the factory carb. I think that i did the de-smog correctly, I received lots of help from people here and I thank you. My cruiser runs fine seems to have decent power, starts and drives fine. I am not a carb guru but feel that it is running lean, I have a hard time starting it after it has sat overnight, I have to pour fuel in the carb and it starts right up and stays running, however even after it is warm I have to full choke it to get it to start then no choke on idle. are there any mixture screws? I can not seem to find any adjustments except two on the linkage which is how I have adjusted the idle. I have heard that there is a hole that has to be drilled out to access the adjustment screw, is this true? Please help, photos are always helpfull
thank you,
ps. I took the 40 out this weekend for the first time in one and a half years. It ran pretty good. I took it to some local sand dunes, lots of people but fun. The only problem was that I was shown up by a couple of J**Ps , so I need to get the carb dialed in to represent better.
thank you,
