850/860....L shocks or regular? (1 Viewer)
rapid city, SD
I have narrowed my lift down to either the ironman 2.5 lift or OME heavy front/medium rear. My question is if I can run the OME L shocks with the heavy/medium setup? Or would there be no advantage to the longer shock with this setup? Thanks
crikeymike
Exit Offroad - Dobinsons Specialist
Supporting Vendor
Jacksonville, Florida
The L shocks would be too long, requiring you to add some other parts too. They're only needed for 3"+ of lift.
Ironman? :doh:
Fredericksburg, VA
I'm currently between Ironman and OME 2.5" (heavy/medium). Please post up your results once you get the lift installed. :beer:
I've heard good things about Ironman. However, I've already installed an OME based lift on another vehicle, so I may just go that route. I already have the steering stabilizer, so that's a few bucks that I won't have to spend.
Zionsville, IN
I have the mediums and L shocks and they are just fine, I can full stuff my rears until they rub the wheel well and I'm not bottoming out my shocks. I am planning on adding the 30mm spring spacer here soon which is why I went with the L's.
Tulsa, OK
Go L's as you may want to add spacers later; they won't bottom out at full stuff on those springs anyway.
P.S. You might as well run a J in the front with the 860 unless you like Stinkbug; just my opinion:)
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
