I have an 84 FJ60 with rebuilt OEM carb and desmogged 2F motor with 174k. Just had the head rebuilt and new gaskets respectively due to a coolant leak into cylinders 3&4. Motor runs better than ever, doesn’t leak any oil. When I first got it back from the shop, vacuum would be anywhere from 16 to 21 for unclear reasons, but peaked at 21 when warm. I’ve had intermittent dying issues at idle happening 1x a week for the last month since picking it up. I’ll back off the throttle to decelerate and shift down and it will fail to idle and drop RPMS until it dies. I can always overcome this with more throttle or with the choke pulled out. It self resolves after a minute or two and I’m back at idle with no issue. I can tell it’s time to push the choke back in because the idle will shoot back up, usually after oscillating between 1200 and 1800 rpms rhythmically for no apparent reason. Any ideas on what’s causing this?
I just sent off my spare carb for a rebuild by Jim. Hoping I chose the right thing to do after pouring over the carb diagrams and thinking I might have an idle circuit issue.
