84 FJ 60 2F Engine Out
Discussion in '60-Series Wagons' started by D'Animal, Feb 27, 2007.
  1. D'Animal
    D'Animal Rescuer of Beagles & Landcruisers Moderator
    21,200
    Media:
    180
    Albums:
    8
    513
    Mar 31, 2006
    Central California
    I pulled the engine out of my 1984 FJ60 last weekend. It has 264K on the Odometer. The PO said he replaced the head gasket and had head work done since it was overheating. It ran great before I took it out. It is going into my 86 FJ60.
    Now that I have it out, what should I replace? The power steering pump leaked and there is oil all down the drivers side of the engine. When it was running I could not find any leaks anywere. The gasket to the heat exchanger is blown. The rear main seal weeps and there is a washer glued to the back of the head on top of the frost plug. The compression is good but should I do a set of rings? I cannot believe that this is the original engine or that it has not at least been rebuild already with 264K mile on it. The oil pan gasket has black looking RTV silicone sealant. is that stock Toyota stuff?
    I do not want to have to pull this thing again in 6 months.
  2. 84yota4x4
    84yota4x4
    363
    24
    Oct 18, 2006
    Chattaboogie
    Just adding my .02 but I would rebuild the bottom end completely just because then you would pretty much have a brand new engine ready to go for another 300K. Its a lot of work and some $$ but I think it would be worth it. I'm actually thinking of a rebuild for my 2F but thats not for while down the road right now.
    -Brian
  3. nikos8
    nikos8
    469
    Apr 27, 2004
    Connecticut
    I would change the rod bearings and main bearings as well as the piston rings. Check the cylinder walls for wear.
  4. D'Animal
    21,200
    Media:
    180
    Albums:
    8
    513
    Mar 31, 2006
    Central California
    I'm thinking that I should get a FSM before I do anything. Is the Haynes just as good? I will want to mic the lower end components before ordering new bearings. The pistons should be stamped if they are oversized.
    I will also need the torque specs for reassembly etc. What else and I missing. Should I replace the oil pump?
  5. GulfShoresFJ60
    GulfShoresFJ60
    888
    3
    Feb 12, 2005
    MS
    Personally I'd get the 2F engine manual Publication Number: 36104E - that is what I used to rebuild mine and it wasn't that difficult. It had all the torque specs and step-by-step instructions.
  6. Dave-T
    Dave-T
    1,546
    1
    Oct 30, 2006
    Heber City, UT
    Hey Dan,
    I've found the 1980-96 Haynes is actually a pretty good manual, even when it comes to the engine stuff. It even has some of the same pics and drawings as the FSM. Sometimes they're written a little easier for someone like me to understand. Although I would definitely get the FSM as well.
    Hope your rebuild goes well, keep us updated.
  7. grant5127
    grant5127
    5,025
    16
    Oct 31, 2003
    Meridian,TEXAS
    if you have the time, money, and resources?? I would go through the whole thing.......
  8. D'Animal
    21,200
    Media:
    180
    Albums:
    8
    513
    Mar 31, 2006
    Central California
    This engine runs great. It is just leaking quite a bit. I'm just going to "freshen it up" a bit. The 2F Dave & I took out of my 86 is going to get the "full treatment".
  9. D'Animal
    21,200
    Media:
    180
    Albums:
    8
    513
    Mar 31, 2006
    Central California
    Aren't Your Going To Help?
  10. augirthedude
    augirthedude
    459
    75
    Feb 9, 2007
    Sandia Park NM
    the washer glued to the freeze plug is not a washer but a an overheat sensor that was applied buy some one who sold or rebuilt the head . these indicators have a material in the center of the "washer " that melts at a perscribed temp. I used to put them on all of my customers engines to see if when the next time they came in complaining of head gasket leaks or over heating problems if this indicator showed that the engine had overheated. wrecking yards and engine rebuilders use them to discount warranty claims due to overheating .
  11. D'Animal
    21,200
    Media:
    180
    Albums:
    8
    513
    Mar 31, 2006
    Central California
    Thanks
  12. Heartworm
    Heartworm
    1,639
    8
    Dec 7, 2002
    Oil leaks
    I have been told that oil leaks around gaskets can be a symptom of excessive blowby into the crankcase from worn piston rings. It probably is time with that many miles.
  13. Dave-T
    Dave-T
    1,546
    1
    Oct 30, 2006
    Heber City, UT
    Sure Dan, PM me when your ready to drop it in. I might be able to come down again.
