So I have recently resurrected Mudhon, formerly Pisoschett, though is very close to earning back its old name, and am having an odd problem.
I have just brought the beast back to life. I have resealed the intake and exhaust as well has had a new exhaust fabricated. I have replaced all of the vacuum lines and verified the vacuum is excellent. I have plumbed in all of the smog junk and can electrically connect/disconnect at will. The truck has that Performance DUY distributor all timed up. When it is running right, it actually gets up and goes even with stock gears and 35's.
Today I attempted a drive on the highway and she started up on a 38 degF morning like a champ. She fell in to a nice idle I figured I was good go to. I got the highway and got up to 65MPH with no problem and was feeling the stoke. Then she started to lose power. As I pulled over she bucked a little and lost more power with each buck. Basically it took on an oscillation where each buck caused another. At the side of the highway I noticed it was idling perfectly but as soon as I tipped in the throttle it would sputter. While running I popped the hood and checked the fuel filter and it was full as always. Admittedly, maybe due to the light, I could not gauge how much fuel was in the carb via the sight glass. It might have just been that low.
So I run out of options and call the tow truck. After about 20 mins I pull the emissions junk fuse I installed and try again. Go figure it runs like a champ - again. I text the tow driver my status and give it a shot. I get about 1.5 miles down the highway to the next exit. As I leave the light it starts to act up. I then get on the highway going home hoping to reduce the tow bill. Unfortunately it bucked itself to a stop on the on ramp and purred gently as it rested there refusing to produce any useful power.
When I got home and off of the tow truck I started it up and it of course ran great to its truck bed in the back yard.
I am bit unsure where to go. The fuel filter is new. If I had a bad fuel pump I'd expect fuel starvation under all loads especially when the choke is on. If the fuel cutoff was not working it wouldn't idle or really run at all. I suppose I could have clogged jets but how do they clear when the vehicle sits of 10-20 minutes? With the emission "off" the EGR shouldn't activate but I guess that doesn't mean it can't. Still, if that was stuck open I'd expect major difficulty idling vs. the gentle lope it enjoys.
Thoughts?
Frank
Thoughts?
Frank
