Ok I am 2 weeks into my project find. Many kudos to all who have responed to my prev posts. All good info and suggestions so far.
I rebuilt the carb and traded a few emails with JimC ( I think the c stands for carbuerator). It runs!!! In order to get it to idle at all I advanced the timing. Still diesels an cugs and needs choke to idle but it idles. I advanced the timing because it had no power on a spin around the block. Advanced timing and now she has some pull and actually runs smooth above 1500rpm or so.
Spent a few hours chasing oil leaks and cleaning things too. Pulled the plugs today and found #3 and #5 fairly well fouled. This could be legacy from the 2 year nap the truck took before it was mine.?? Anywho read the thread on vacuum analysis. Hooked up a quality vac guage to the vac switch hose (small one) which shares the finned valve and larger hose to the brake booster/manifold path. Pulling 5-7 inches of vac at 6250' elevation. It bounces from 5-7 inches as she chugs and idles with the choke out a click. Exhaust smells clean. Oil looks good. No clacking or tapping noises from the block. Sprayed more than my earth day share of carb cleaner all around seeking the elusive vac leak none found. Solenoid is good -bu the vac switch IS bad. Can this switch cause this problem? Any other paths to follow? I am open......I am having fun chasing away the old ghosts in this machine....I will make it run....I willl make it run........all I need is a lifting platform and a lighting stormmmmmm.....ah hahahahaha!!!! OPPs sorry wrong movie.....ahem ........can a brother get a clue here?
Thanks.
Thanks.
