Replaced alternator in my fj40 and wiring was rigged up weird to the old one so now I’m trying to figure out what goes where
Would just like to know where these wires need to be placed, I know where the ground needs to go but the other three I have no clueThis is a area i specialize in
I can help here
Let me know what info u need
Kindly matt
How is it compromised? And I’m sure I can figure it out with your info thank youYour ring terminal is compromised and needs replacement before u install
FYI
It’s a issue
Ok I can fix that but the other wires I had routed in red were correct??fatigued ring termial at the bend
then
broke insulation will snap these fragile corroded copper lead
this is FULL battery voltage remember
were u get the blue repair connector ?
thanks
And VintageTEqParts.com
Perfect thank youDoes this photos tell you clearly how to hook it up ?
View attachment 2894133View attachment 2894134
Just did a full knuckle rebuild Not good with electrical though so thank you
