80's Transmission question? I have a 1993
N.C.
80 series and somtimes when I shift it in to drive I do not get full power. I can put the transmission in to 1st gear and get full power and then shift up to 2nd and 3rd. Sometimes if I shift it in to drive and don't get full power I can also shift back in to park and then back to drive and everything acts normal. This does not happen very often but I thiught I would ask to see if anyone else has had this happen and what the fix was. Thanks.
1. Search, and it will say to:
a. check fluid level first.
b. Drop pan and clean screen/filter
c. Adjust tranny kickdown cable?
Mine's done it about once every year since it was a couple years old. What's likely happening is you put it in drive, but it starts off in 2nd - giving you the feeling that even floored it will not take off. One day I played with it and it is more likely to do it if you shift into D and immediately roll on the throttle like you're in a frantic rush. I wouldn't freak unless it starts doing it more often or changes. Fresh fluid should always be on the menu.
DougM
Yers is broken.
:lol:
need to check trans fluid
Having symptoms of sluggish shifting ... want to check transmission fluid level. WHERE do I check?
BTW...I always come to this list when I need info on my landcruiser. It has seen me through rebuilding an alternator and radiator issues over the last four years. THANKS!!!
GWEN
Proud mom to six kids (16 to 3 yrs old)
and a '92 Toyota Landcruiser (191,000 miles)
Nah, not broken - just heals itself for thousands of Park to Drive cycles, then does one wrong and immediately fixes itself. Like Christine. Yeah - just like Christine...er...gulp.
DougM
Wish I had it! I'm not the original owner. Any guidance would be appreciated
Gwen
Do you know which dipstick is for the oil? If so, check the other dipstick. This transmission dipstick *should* have an orange handle. It has two sets of fill lines: one for checking the cold transmission fluid level, and a higher pair of lines for the transmission fluid level after you've driven a few miles (~15 miles) and thoroughly warmed it up. The transmission should be in park, parking brake set, and engine running while checking the fluid.
Also, an owners manual, as well as factory service manuals, should be available from the Toyota Materials Distribution Center @ 1-800-622-2033.
