$800 for 1” of Lift? Other Options?
Nationwide, USA
So my current lift was not designed to handle the weight of a 4plus rear bumper and a 40 gal fuel tank.
According to my measurements, I’m at 2” of lift at both ends, but that’s with zero gear in the back or on top.
I have priced out OME rear springs but when all is said and done with shipping it’s going to cost around $800 for rear springs only, not including installation.
I haven’t found any shackles that would get me the 1” I need, as my current ones are 4.75” pin to pin, on center. The tallest ones I have found are 5.25” pin to pin.
Are there any options anyone is aware of? I’d rather put the $800 into a front bumper, though it won’t raise the rear, it will bring down the front to eaven out both ends.
Thank you!
OSS
Oblivion
That’s the thing about big bolt on bumpers - gotta replace the springs too because of the weight.
Memphis TN
What kind of leafs do you have? OME D2XL is a long add a leaf designed to increase the payload capacity of your leaf pack. It installs into your leaf pack and they run at around $29 a pop at Cruiser Outfitters. When you do your front bumper, the front add a leafs part number is OME D1XL. For all 4 corners thats $116 so that would leave you about $684 for that front bumper of yours.
Nationwide, USA
search for information on add-a-leafs
The lift is HFS brand from Cool Cruisers of Texas. I put this lift on it soon after purchase in 2005 with little research. Not a bad lift system, I just hadn't planned ahead for the additional weight of the rear bumper and double size fuel tank. AALs aren't really an option. I've already had a local spring shop add a leaf or two and it's still the same.
Yep, see above.
I believe I found a good solution. Air bags, but the ones that seem to work the best are a bit expensive. Probably in the $395 range plus shipping. May be worth it for a plug n play and adaptable solution. Vary ride height depending on load.
Boss Air Suspension. See this thread describing install and usefulness:
