will the tcase out of my 94 80 series swap to my wife's 06 100 series?
Just Differentials did the swap. He just shortened the drive shaft by 3 inches. I am going to do this swap myself. I am shopping for an 80 series HF2AV TC now. Then I am gonna do the lower low range gears. I also like having the viscous coupler because then you can traverse on nasty roads (center diff locked) with little danger of driveline binding. I especially look forward to using it on snowy/icy/muddy paved roads.
Yes, that is the basic function. Allows enough slip front to back to prevent binding.It's been a while since I had an 80 series, but I thought the function of the viscous coupler was to act as a "limited slip" (between the front and rear axles) when the center differential was "unlocked"?
I imagine Mr. T did away with the VC in the 100 due to the active traction control making un-necessary.
EDIT: Since the VC comes after/to the rear of the locking function in the TC it is always working. Becomes even more valuable/functional when center diff is locked.
The VC cannot be turned off. Therefore is always functional.Viscous coupler is not used when center differential is locked. Viscous coupler is active when center differential is NOT locked.
Yes you will. The locked function and VC work completely independent of each other. Same as if you had a VC or LSD in the front or rear differential. It allows a bit of speed variance between front to rear as an axle/diff would side to side. It is a very simple device it cannot work any other way. Were the VC to fail, it fails in a 'locked' manner (no speed difference ).
-class dismissed, good night.
I am by no means an expert, but I have owned or modified several vehicles with a center VC. Some combined with rear and/or front lsd (helped build my cousins modified Audi, which had all three). VC's like the one in the HF2A(V) have a sealed VC that, to my understanding is a little loose or some say sloppy. Probably do to having a thinner viscosity fluid inside. In this case of thinner viscosity it will contribute to a feeling of drive-line 'lash' or play. So this sealed VC has several plates/discs inside that have to rotate through this fluid. When the difference in rotation front to back no longer overwhelms the resistance provided by the fluid. Example: fill a small glass with honey which is a thick or high viscosity. Then stir it with a stick, the glass will try to turn with the honey. Now try the same thing with water, you would have to obviously stir the water very fast to get the same result. In this example the stick would be the power from the engine into the VC and the glass would be the the power going out. Just like an LSD it works both ways left/right, or in this case front/back. This amount of differential in speed (great or small) is what relieves the potential binding.
I am looking at about 2 or 3 different HF2AV's on ebay now. I will be buying one soon. Then I am going to rebuild/refresh it and install some trail creeper gears myself. I have rebuilt a few transmissions and a couple engines before but never a transfer case. It looks pretty straight forward though. I attached a nice HF2AV schematic for your viewing pleasure.
Not just less binding with the diff locked. Less binding at all times vs the tc without vc.
I was simply trying to highlight a benefit that you have ZERO understanding of.
