Have you followed any of the advice in this thread?I have the same problem. I have new shocks and springs. Still wanders a lot.
I just found this thread a few days ago. I'm definitely going to replace all the bushings. Thanks. Not sure if the lift will be causing part of the problems. Especially if I go to 35 inch tires. I currently have 33's. It has castor correction bushings, but I don't know if it needs other things for everything to be in correct alignment.Have you followed any of the advice in this thread?
I would add bushings to the list of things to check, and don't overlook the rear control arm bushings. My truck used to steer like a skateboard- overcorrecting with each twitch of the wheel that caused any lean. It turned out to be trashed rear control arm bushings, mostly.
