Hello to all, again. I’m slowly fixing the suspension woes on my new (to me) 80 series. Rear pinion angle/driveline/coil alignment is my current conundrum. With the current 6 inch lift the rear pinion angle is off of course. I have picked up adjustable upper and lower control arms but when I try to adjust pinion angle to the point the the coil buckets (upper and lower) align properly, the rear driveshaft U joint is at a disturbing angle. I would think that an angle like that would put unnatural stresses on the joint making it a natural fail/wear point. As this is my first coil sprung vehicle I acknowledge my ignorance but I’m certain that the upper and lower coil buckets need to be aligned but also know the unnatural alignment on the pinion in relation to the driveshaft/ujoint needs to be addressed. Am I over thinking it or is there a fix to this problem? Thanks again for your time and advice!
