- Location
- United States
80 series random parts including 2 FSM's-1996-GA
100-series pads for rear PN 04466-60070 (new) $50
drive belt PN 90916-02353-83 x 2 (new) $10 each
A/C belt PN 99332-10910-83 (new) $10
A/C dryer PN 88471-50020 $25
Antenna mast/motor used, motor works, mast is broken 86300-60050 (used) $20
Center caps x 4 needs paint (used) $30 for the set of 4
OEM A/C compressor (used) $20 (needs new nose which is ~$50)
Diff fill plugs from SOR (new) $4 for both
Distributor O-ring PN 90099-14118 (new) $1
End caps for running boards (used/broken) ?
Exhaust manifold stud/nut PN 90179-08040
Exhaust nuts x 13 PN 90179-10169
FIPG 3oz PN 00295-00103 (opened/hardly used)
FSM x 2 one is in good condition ($75) the other is fair (no missing pages but binding is broken/repaired—all pages accounted for) ($40)
Haynes manual (heavily used, but all pages accounted for) $25
Intake manifold gasket x 2 PN 17179-66010 (new)
OEM filters x 2 (90915-20004) $20
Plate washers for head bolts x 2 PN 90201-12222 (new) $3
Locking lug nuts X 3 with key (used in good condition) $20
Spark plug gaskets x 6 (new)
NGK spark plugs x 4 BKR5EYA 2087 (new)
Tie rod/drag link/ends OEM (used) $30 each
Water hose PN 99555-10200 (new)
Water hose PN 87245-60340 (new)
Water pump gasket PN 16271-66020 (new)
OEM water pump (used-good condition) $25
