^ really ? bring me a thread on ih8mud that has these exact photos ? ( not similar ) the same exact photos
Oh please,
OK they are cool but, there are quite a few you tube videos as well
How is this tech anyway?
Most of the other threads like this got moved to chat
I am just waiting for it to happen
I do have an actual tech question. In the second video it is quite clear that the wheels in the air are not spinning forward or reverse. If the diffs. where locked they would be spinning forward. if not, they should be spinning in reverse and eventually no forward motion would be possible. Do they use a limited slip or do they have 4 wheel independent braking control to lock the wheels that are in the air and put power to the wheels on the ground? I can understand the balance part of the trick and the deep pockets that allow you to learn without worrying about wrecking your truck but I don't understand how the drive train works in this trick.
If you watch the videos, you will see the front tire in the air is stopped and the rear tire in the air is spinning, I think a rear diff lock is being used.
