OK, I've always known the 80 series frame was really overkill compared to other brands. The fully boxed frame from end to end sets it apart from other brands. However, the inside is equally as impressive. I removed all the suspension components on this frame for use on another project. At each frame mount the frame is double thick on both sides. 4 layers of steel and these tubes are welded in to keep it from collapsing. Check out the tubes and layers at the steering box. No wonder Cruisers don't have cracked frames at the steering box like a lot of domestic pickups do. Not too often would you get to see the inside of a frame so I thought I'd share a few photos.
