OK - I'm calling BS here.
You can't remove the dual alternator belts without removing the AC compressor belt - fact. You can't remove the AC compressor belt without getting under the truck unless you have a genie in a magic bottle.
I replaced the factory POS alternator tensioning lock bolt with a good square bolt to eliminate the problems that the factory unit causes. Use a good quality six point socket and you should not have any problems with it. Once you get it out replace it with a like size square shouldered bolt and you will never have any problems again.
And you won't have to take the fr#@ken battery box out. What a total waste of time. LOL
The tensioning adjustment bolt is very easy to reach from the wheel well unless you are blind or something.
Geez....
Geez....
