79 series fuel gauge
Yackandandah
Does anyone know of a fuel gauge to suit a original 79 series fuel sender. The full resistance is 12-18 ohms, empty is 405-415 ohms. I have not been able to find one that works with these values.
I have a 79 series 2011 single cab that came with one 90l tank. I have fitted a genuine Toyota 90l tank to the rear & connected it up to the existing wiring looms. The dash gauge has only one fuel gauge & I have used a relay to switch the gauge between tanks. This works, but for some reason the gauge takes 5 minutes to switch between tanks.
I would like to be able to read both tanks fuel level.
Thanks, Kevin
I got mine from toyotadxb.com. Mine worked right out of box. I had vdj and "basic" versions.
I assume you need a vdj version. Ebay.com.au was the place I bought a used vdj cluster w twin tanks to play with.
