G'day Rosco,
could you help me out with a problem if at all poss, I am working shift in ******** oil patch and have some problems with the brakes sticking on on 79 series pick up, 2006, has any thing been documented because I know you boys run a lot of them in the mines in Aussie..
Usually if its one or two wheels its the caliper pistons are stuck.
Its not a regular problem that I am aware but it does happen.
Are they being driven rough and hitting the brakes hard all the time?
I got this as a PM but couldnt return it as his computer is not set to receive PMs
Maybe someone knows what the problem is.
if it was linkage wouln't the pressure have built up on the gauge as the pressure would not return to the res' through the MS ?
adjusted rod from booster to master cylinder and up to now all is fine , but there are a few things unexplained , will keep you all posted, thanks for the help every one, networking is a wonerful thing
