'79 FJ40 Top to tub gap.
Content may include affiliate links. Please see terms for details.
Lenoir NC
Been test fitting 5/79 body parts before paint and having trouble with the gap between top and tub. The top is resting on the windshield frame as it should, but the top does not sit all the way on the tub along the sides. Also gaps at the bow to doors not even. Windshield is down as far as it can go at the hinges. Gutter bends up at the door. (Gutter will get replaced).
I took pictures of this gap situation (pic 1) and also have pic of top sitting on tub correctly with windshield laid on the hood (pic 2).
I am using all weatherstrips needed to test fit correctly. Are there different heights in windshield frames? When I purchased vehicle, it came to me totally apart, body off frame and parts in boxes, so can't guarantee all parts are 79.
I would be checking along the frame. Would not assume the problem can only be the windshield. How is the gap across the bottom of the door?
The is my pieced together 79.
Doors are from a 75. Top is off a 77. Back door 84. Everything fits yours appears thee cowl is higher than where the B pillar is on the tub. Alignment starts at the bottom. Bend frame or body mounts can cause a problem at the top.
Lenoir NC
View attachment 3223669View attachment 3223670Doors are from a 75. Top is off a 77. Back door 84. Everything fits yours appears thee cowl is higher than where the B pillar is on the tub. Alignment starts at the bottom. Bend frame or body mounts can cause a problem at the top.
The door gaps to tub are good. The mounts seemed good as the body sat nice on the frame when bolted down. I could snap some dims from the cowl to somewhere like the post base at b pillar but I would not know if the dims would be good. Definitely something to double check.
Pictures form the side straight on some times help see things. Your door header are a two piece part. They do not look to be assembled. Can see a gap between the two pieces. The bottom piece goe into a channels the top piece. Would get that right first. While it can be done assembling that before setting on the windshield is easier.
Lenoir NC
Yes, you are correct. The door header/bows are temped in. I will make sure they are aligned and bolted down.
1911
chupacabra
Parker County, Texas
My factory original top and doors fit decently on my (12/79 build) 1980. Are you using all four of the rubber gaskets between the sides of the hard top and the tub?
Looking for some close-up photos of mine ...
Here's what I have on hand:
There is a small wedge of a gap between the front of the doors and the top of the windshield frame. Part of that may because of the thickness of the marine carpet that I had put in for a headliner in the top (interfering a little with the windshield frame because the upholstery shop installed too much carpet towards the front).
Lenoir NC
Thanks for the reply. Yes, I have all the weather stripping in place because I am test fitting before paint.
