- Location
- United States
Here is what I have:
OEM Toyota power steering box
Cooling lines (has issues that I will elaborate on)
High pressure line
Low pressure fitting
Rag joint
Steering column
Heat shield (very good shape)
Misc bolts
The pump seems to be in good shape and it was dry but if I were going to use it I would probably rebuild it but that's me. The steering column has the ignition but I don't have a key. If you use the ignition it shouldn't be hard to have a key made. The column would need maybe some clean up and paint or use as is. The heat shield is nice with a small amount of surface rust but solid. High pressure line looks good but it's untested. Now to the cooling line. It has a pinched area that I don't if it can be fixed. At the least it would be a good guide to make another.
PRICE $1500 for it all plus shipping.
PayPal as a gift or you can pay me the 2.9%. Other payment means can be discussed.
Swamp Thing is first in line.
I will see if anybody wants this here for a few days and then off to eBay as bad as I hate doing it.
