- Joined
- Mar 16, 2003
- Threads
- 201
- Messages
- 615
Researched via the search engine but still not quite clear - so here goes...
Have the OEM stuff to do the door upper channels / "squeegee" part / and inside door channels.
Doors are completely broken down (shells only - ready for reassembly)
(1) Can I simply place all my weatherstripping "stuff" in now, then install the glass after the other hardware is in place?
(2) There is a difference between the lower channels/tracks in the doors fore and aft. The foreward channel has a tab near the bottom which I assume keeps the rubber/felt from sliding down and out. The rear channel does not. The original piece removed evidently had a bit of adhesive to hold the felt in place. What is the correct positioning of these rubber/felt pieces in the channels/tracks? Positioned all the way down in the channel?
I pulled these doors apart over three years ago and cannot remember a few minor details - esp with respect to the correct position and glueing of the rubber/felts inside the lower channel/tracks.
As always, thanks for the assist!
Cheers,
Dave
Cheers,
Dave
