NEW PICS 79' carb linkage
I'm having an issue w/ the carb linkage for my fj40.I have a beautiful rebuilt Aisan carb, and many shiny linkage parts. Have used SOR's pic for reference and almost have the linkage connected. The horizontal rod w/ ball ends which attatches to firewall bracket on 1 end ,and to a bracket mounted to carb studs on the other, appears to be short. The firewall bracket side looks like it should hold the ball end of rod in a rubber grommet. When all is connected, the ball end is just pressed against the grommet, not passing through it. It looks sketchy, I dont believe thats the correct assembly. The carb end is held securely in a cup w/ a pin securing it. The pedal functions and all the parts acctuate,but I have my doubts. I have numerous brackets and supports and have tried multiple configs, and this is as close as I've gotten.Some of the parts just flat out cant be used because of bolt spacing. Any in put would be appreciated. I will try to post some pics tonight (or asap) Thanks! Here are the pics- I'm not sure how to place captions, but they are as described in post.
Thnx again !
Thnx again !
