79 Aisan carb install
( this post is originaly from the 40 forum but it was suggested to me to try the 60 forum due to lateness of carb)Hiya- I'm plodding along on my carb install project and have hit another snag. After scouring the posts for anything carb and vac related, I found this thread which worked out the vac lines in an almost identicle situation. Almost. Evidently, my 79 carb is just differant enough to be a pita. Honestly, I have only a very basic knowledge on carbs and vac theory- I just want to finish my installation.I understand that there will be adjustments,etc but I'm under no deadline.(though I miss my dd) OK- Heres the issue- connection F is different on my carb.Instead of 1 line coming out, I have 2 vac ports there.It is either that,or that one port in the middle replaces F.None of these connect to the down angled port which the 78 carb has ( connection "F").
If I have gathered correctly,all the connections I need are as follows:
1. vacuum advance from dis. to connection
2. fuel in- connection
3. switched power to fuel cut sol.
4. my missing F connection
I have capped all else, w/ the exception of 2 ports on insulator block.Can someone help me work out that "F "connection? Thanks to Trollhole and co. for the excellent thread I've been working from. (the diagrams were most helpful)
NOTE: Pics from Trollholes thread have been deleted, as I was told that carb was significantly differant from my 79. Therefore, references to "lettered" connections were not applicable. To see the post w/ quoted pics intact, look for same named post in the 40 tech forum. My god, that confuses me just writing it.
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
[/URL]
Shortbus40View Public Profile[/url]Send a private message to Shortbus40[/url]Send email to Shortbus40[/url]Find More Posts by Shortbus40[/url]Add Shortbus40 to Your Contacts[/url]
[/URL]
Bookmarks
Bookmarks
