79+ 2F Engine Block
Discussion in '40- & 55-Series Tech' started by McGruff44, Jul 12, 2005.
  1. McGruff44
    McGruff44
    192
    3
    Jun 23, 2004
    Peoria, Arizona
    First off can anyone tell me if I can swap a 79+ 2F engine block for my 75 2F? Will all of my 75 2F parts bolt onto the 79+ block. I want to add a factory power steering pump and factory AC to my rig. If so, does anyone in the SoCal area have a 79+ engine block for sale thats in decent shape?
    Thanks for the help,
    Vern
  2. SpaceGhost
    SpaceGhost
    467
    2
    Feb 1, 2002
    Indianapolis, Indiana
    Yes you can swap them, everything you already have will fit.
  3. Texican
    Texican s-Moderator
    5,964
    Media:
    175
    Albums:
    7
    321
    Dec 17, 2002
    Bonham Tx.
    Has anyone ever tried drilling a tapping an early bloc for the OEM pump.....?
    Although now that I think about it, I would rather have a Saginaw pump by at least 100%
  4. Gumby
    Gumby Supamod Staff Member s-Moderator
    12,226
    680
    Dec 13, 2002
    Knee deep in hookers and gin
    I thought about it recently.
    You just talked me out of it. A saganaw pump is far better and easy to mount.
  5. cruiseroutfit
    cruiseroutfit Supporting Vendor Moderator
    8,832
    6,602
    Jan 9, 2003
    Utah
    Yes, there have been several done round here... Toyota had one done (bought a block from us to replace the one they destroyed in a customers rig, I guess you do have to add oil :D)...
    The other was done during a rebuild, a local machine shop did the work, not sure how deep they drilled them though, the same material should be there, but risky IMHO
    I prefer Saginaw too, especially mod'ed pumps :D
  6. FJ40Jim
    FJ40Jim The Cruiser Whisperer SILVER Star
    10,352
    Media:
    1
    2,731
    Sep 26, 2003
    Lancaster, Ohio, USA
    Vern,
    Yes, all the 75 guts will swap into a 79-later block. The only thing on the block that is any different is the location of the oil sender, it wanders around from block to filter base to oil cooler to filter base, through the years. They oughta put a leash on the thing.
    But since you ask, I'd suggest just getting a complete 81-later 2F w/ the factory PS holes and oil cooler and clutch fan and close chamber head and 3-piece exh manifolds and lightweight valvetrain and electronic ignition and vacuum advance distributor and....
    :cheers:
  7. McGruff44
    McGruff44
    192
    3
    Jun 23, 2004
    Peoria, Arizona
    Thanks everyone. I was going to rebuild the engine so I would have the block stripped down anyway. I have seen the Saginaw pump brackets for sale but wasn't sure of the Saginaws performance. So it sounds to me that everone prefers the Saginaw pump over the stock pump. Is this because it performs better and/or is it easier to find and buy?
    I wanted to put the power steering gear in or near the stock location (more or less to keep it somewhat stock looking)
    Thanks again for the advise.
    Vern
  8. Texican
    Texican s-Moderator
    5,964
    Media:
    175
    Albums:
    7
    321
    Dec 17, 2002
    Bonham Tx.
    All of the above, plus it's way cheaper up front and if it needs replaced...........If you don't have a smog pump get the bracket that mounts it low next to the Motor mount.
    Butch
