Carb issue sounds like it cut be the fuel-cutoff/idle solenoid. Does it start and then die? Can you keep it running by keeping the revs high with the gas pedal?
I blasted the rear end. Not fun. I was drenched with sweat and grit after the 1 and a half hours of blasting. It was definitely not much fun. Not sure if it should have taken that long or if the harbor freight blast I used just sucked.....
It turned out pretty well though.
Then I degas see the entire assembly in the powder coat oven at 430f. I wanted to be sure any oil on/in the cast parts was baked out so that I would get a nice finish on my powder coat. I let that degas for about 2 hours (possibly longer than needed).
Then I used prismatic stone black (maybe a 10% gloss) for the axle. Turned out beautifully. I did have to bake it twice because I did not get a full cure on the cast parts the first time. Someone misplaced the laser thermometer so I had to guess when the part hit target temp (400f) and apparently I was a bit short for the thick castings. Luckily it fully cured the second time (after running it by the tech support team at prismatic).
Here is a shot of the assembly getting ready for the spray booth. Notice the plugs on the ends. I made them out of cardboard that I cut on our 70 watt universal laser. It's so handy to have that thing available.
Here is a picture of the assembly going into our oven.
And the finished part.
Good question. I spaced the access cover off with a cardboard spacer (used the pattern I made for my gaskets and cut it out on our laser) so it is completely removable without any problem. I did leave the diff on to pc (in hind sight I wish I would not have) but it I'll likely just run around it with a blade when I need to remove it. It should not be difficult to cut the bridge between the diff and housing.
