78 FJ40 overheats even without thermostat
Winchester, IL
I have a 1978 FJ40 that continues to heat up. The first step I have taken is to replace the thermostat, but found out that there was not one there. Radiator looks good, coolant level in good, there are no leaks when running or otherwise. Anyone have any idea's? Thanks for looking
the thermostat also work to keep the water in the radiator longer, so the fan can cool the water down some, before it goes bcak into the engine. Most cars can't run without one. I'd put 1 in there & see what happens...
there has to be no more than a 40* difference in temp from the upper to lower radiator hoses. that can help you figure it out..... put a stat and a pump on it just to get rid of problems, because you already half way there!!
Are you sure it's over heating? Is it boiling water out or or you just going by what the gauge says?
X2. These gauges (as many have said before me) are at best idiot lights. If you are basing this on your stock gauge, I advise you to get an aftermarket one. At the very least, put a meat thermometer between the coils of your radiator. That will give you an idea.
Here's my story with stock gauges. Basically, I like numbers. So I added an Auto Meter temp gauge. It showed I was running about 125*F. I was in the "normal" range on my stock gauge. I figured my thermostat was stuck open. Opened up the housing and no thermostat! I put in a stock 185* thermostat and ran it. The Auto Meter gauge showed I was running at 185*. The stock gauge stayed almost in the exact same spot it was in before (in the "normal" range). That is why I like numbers on my gauges.
Another idea is: have you burped your radiator? You could have air in the system.
Good luck! :cheers:
Just my 2c but I am a firm believer that if one part of a system is bad the others are probably on their way as well, go down to an AC shop or your local HDW store, get one of those AC thermometers..long pointy shaft with the dial on top, slip it between the fins of your radiator and run it up to operating temp, you can watch the temp rise and fall if everything is working properly, this will give you a starting point.
Open up the block drain, if nothing comes out and you are full of coolant, you got crap in the water jacket and coolant isnt circulating properly, plumb in an aftermarket gauge, if you dont want t in the dash, mount it under the hood, they are more visibly reliable that the stockers, pull the radiator, have it rodded.
Have you had the system open and drained a bunch of coolant? you probably need to burp the system...it goes on and on, just verify all the components are working correctly, you will find the bad one, take your time, and as crazy as this sounds, check the direction the fan is installed...I was on the phone in the garage with a buddy when I was having cooling issues, he told me a story about one of his where he had the fan installed backwards, as I am saying how could anybody be that stupid, I am looking at mine and DAMN! the PO had put the fan on backwards!
OK, so it was more that 2c, but you get the idea.:cool:
Is your fan clutch working? Give the truck some healthy throttle and see if the fan stops spinning when you goose it. Does it do it at idle or also on the freeway? Just saw you are from Illinois. With your weather what it is and still having this problem makes me think it's either pump or radiator related as I currently have all but a 6x6 square opening on my radiator covered up and I am staying cool just fine here in Washington.
Brittain
regardless......start by putting a t-stat in.
How about a little history. Does it have the 2F or a V8. V8s don't run very cool with a stock radiator idling in traffic or running slow on trails. I can see by your other posts this cruiser might be new to you. If it is has it over heated since you got it. Try running the heater. If it is runnig hot you won't be able to hold your hand in the discharge air.
John
x3.14
I can say from personal experience that lack of a thermostat is no way to drive your truck. The times I've done it is to circulate stop-leak, and it ALWAYS over heats if you go too long.
If you have an F or 2F, when you drain the coolant from the block, dig into the water jacket through the drain plug hole and get out all the crud that has built up between #5 and #6 Cylinder with a long, thin screwdriver.
Mine was so bad that the coolant wouldn't come out when I removed the drain plug.
It only helps in that one area, and a lot of crap will remain inside the water jackte, but you can only do what you can do!
On my '74, the plug is on the drivers side above the oil pressure sensor.
Rocky
A bad waterpump, plugged radiator, plugged water valley, or even radiator cap (the pressure added to the cooling system actually raises the boiling point of the coolant, allowing it to absorb more heat).
Of course all this could be pointless if you're running a turbocharged small block or anything else other than stock.
Kevin
The engine is a stock one with 89,000 miles. The engine did actually overheat and boil over the last time I took an extended drive. Thats when I pulled in the shop and started working on it and several other things. I wasn't aware that the thermostat was missing and that was just a starting point.Now, thanks to all you helpful and knowegible folks out there, I have some ideas on how to resolve my problem. Thanks for the input and your time. AJS
Rocky
I concur. I am tearing apart my engine and have found coolant crud partially blocking the outlet of the water pump, the water jacket opening into the thermostat housing, etc.
