Devilmans Hand
TLCA #19517
- Joined
- Aug 4, 2008
- Threads
- 140
- Messages
- 3,467
- Location
- Commonwealth of N.VA
- Website
- www.capitallandcruiserclub.org
Yea, this is another thread started by me.
I'm addressing the stuff i broke this Mem day.
Tail light lenses are only $17 from the dealer, and mine now contains a beercan light section divider because the original is somewhere on Trickle Creek.
I started ripping off my rear plastic fender flares on the trail, do i need them in VA and surrounding states to be legal with regular plates? I'll measure how much the wheel extends outside the body sometime in the near future if it matters.
I'm pretty sure that I need some more backspacing on my wheels. Jon pointed out that my wheels do not turn as far as everyone else's wheels. I can also see a nice shiny line where something has been rubbing on the inside of the wheel when the wheels are turned as far as they'll go.
now comes the important part
When I was coming back from the trip going up that huge hill on rt. 17/50 the cruiser started bucking in 4th gear. I figure all the off camber and jarring on the trail worked some **** loose from my fuel tank elsewhere into the fuel line. I changed the fuel filter, stock type right before the fuel pump, but I'm still getting some bucking when under load, usually around 1800rpm.
This thread, https://forum.ih8mud.com/40-55-series-tech/310245-gas-starved-4th-gear-only.html
also mentions that this could be ignition related. Everything under the hood seems tight and where its supposed to be. I have a stock '78 FJ40 CA Carb Smogged and stock type fuel pump. I don't have a timing light or any special tools. Does anyone have any ideas of what could cause these symptoms to suddenly appear after wheelin a bit?
