Hi All:
Well, a few years ago I helped-out on swapping the 2F from a '77 FJ55 into a '76 FJ40, so here are a few hints:
1) As mentioned, the *J55 Series uses different motor mounts than the *J40 Series, but you can use the "F" engine 40 Series mounts with the 2f;
2) The water pump on the 2F in a FJ55 is longer than that used in a FJ40, but you can swap-onto the 2F the water pump and fixed fan from the "F" engine;
3) I think you may have a clearance issue at the center cross member when installing a four speed transmission into a rig that came with the three speed tranny (which is shorter), but I'm sure some one else will pipe-up with a definite answer for this question;
4) As mentioned, the drive shaft yokes are different between the three and four speed transmissions, as well the drive shaft lengths are different between a FJ40 and a FJ55, but grab the '55 'shafts anyways, because you can mate the short splined ends (with four speed pattern yokes) to your stock FJ40 drive shaft tubes (with the correct yokes for your axle diffs) and make 'em work;
5) You can keep the clutch slave cylinder on the (stock) driver's side, but you will need to use *all* of the four speed clutch parts, including the fork, pivot, etc. I don't know whether the three speed slave cylinder will work with a four speed tranny or not.
Good luck on your project!
Alan
