FYI, I have read just about every thread on coolant.
What prompted this was some bad lines and I had not performed this since owing the vehicle. Never overheated, just start to leak a bit from the upper rad hose, so thought I'd do it.
To date flushed and drained the entire system aside from removing heater lines and core. Flushed 2x using Preston and then again using Blue Devil and finally water. Replace most lines and t stat. It was pretty dirty!
Removed both radiator plug and engine low point drain. Nothing ever came out of low point? I ran engine for a few minutes and nothing. So closed her up...
Filled with about 1 and half gallons of preston 50/50 and rad was showing full. Ran around the block burped and still showed full. So knowing I likely had water still in the system, I drained the system, which totalled almost 2 gallons even.
I then refilled to get approx 2 and half gallons and again is showing full.
I am a newbie, so haven't done much of this before. However manual shows I should have 18-19 liters and I put it approx 2.5 gal or roughly 10 liters.
I will say it feels as though the rad seems warmer and the upper main hose to t stat, however thats a full assumption having never really paid attention to the area before.
Your assistance is much appreciated!
Josh
Josh
