I have recently purchased a 77 LC with front disk brakes. The brakes work well but the brake pedal is extremley hard to push down.
The vaccum line was disconnected from the brake booster. I suspect that is why the brakes are hard. I reconnected the vaccum line last night. It seems to have helped somewhat but you can hear a hissing noise when you press the brake pedal. It appears there is a leak in the vacuum line and or booster. Can you tell me what steps i should follow to isolate the problem or determine if i need to replace the booster. Is there a way to test the vaccum on the line to see if it is sufficient? What should it be?
Should i expect the brake pedal to be somehwat stiff but not hard to push or are the always stiff?
Any thoughts or direction where to look is greatly appreciated .
