75w -90 Syn Gear Lube...Any objections?
КАГІҒОЯИІА
I have searched and searched soooooo....
If I run out and buy the Mobile 1 - 75w -90 Syn Gear Lubricant to replace both diffs and my center diff or T/C or whatever it is...
Would there be all YAYS from you guys (and gals)?
Is this the preffered in all units?
Thanks!
Here is the amounts you'll need, (thanks to Acolella)
Transfer case: SAE 75w90, 1.7L
Differential, front: SAE 80w90, 2.8L
Differential, rear: SAE 80w90, 3.25L
I changed to M1 motor oil in my 80 recently and just did the front diff (M1 75-90) yesterday and plan to do the rear today. Man, this stuff is expensive!
I recently got bitchslapped by the forum for using Fram filters. Apparently, using M1 made up for my knuckleheadedness.
M1 all the way.
This looks like the amounts for a non-locked 80. Locked 80 diffs take less fluid, if I recall correctly.
So, 80w90 in the Diffs??? I thought I read it should be 75W90 all the way around:confused: I just went out and bought all 75 w 90. Am I headed back to the store?
Also, what is this 75 w 140 Mobil1 I saw at the store? Says it is for SUV and Trucks, is this not good stuff for our vehicles?
The 75w-90 works great everywhere. The 75w-140 is the wrong viscosity for Toyota diffs. They spec out 90w at operating temps, so the 75w-90 is ideal. I did think that Mobil1 in the transfer case did slightly improve my fuel mileage. The diffs did not seem to matter that much.
One lesson I learned, is that running the expensive lube makes it psychologically$$ harder to change if you run a bunch in axle deep water. If you spend much time with the hubs wet, you'll want to change the gear lube in the diffs to get the water out. For that reason I went back to conventional lube (Chevron Delo Gear 80w-90) in the diffs and don't sweat the lube changes. Also, don't forget to extend your diff breathers.
I use the Red Line Gear oil. In some places, it's cheaper than the Mobile 1. I buy it by the gallon and use a pump.
M1 75-90 all around here - for 150,000 miles since breakin. My axles are dead quiet just like when I bought it.
DougM
Currently my transfer case has 75w-140---the coldest it gets here is the high 50's and in the summer it gets up to 115. Do I need to change the transfer case oil? My diffs have the spec grade. One other question is we run in river often, and I extended my diff breathers--how often should I change the diff oil?....I put on about 10k per year--currently have 146k.
Ah YES and YES.... I would change diffs after any deep water ASAP, and get your transfer case swapped out on a cycle depending on what you put in and what kind of driving your doing.
-Ammo
SG - so you haven't extended the center diff, locker or transmission breathers? Do a search on people who've connected them all atop the tranny, then run the combined rear/tranny/center diffy up next to the front diff. Can't recall if the little breathers on the locker mechanism were included.
Better check into that and I agree with the daily changeout of these if you're wading deep. For that use, you're way better off with clean cheap stuff in there than water contaminated Mobil 1. Also a good idea to have a tube of grease and hand grease gun along on a multi day wading trip so you can purge water out of the drive shaft joints.
DougM
So first choice seems to be Mobile 1 for synthetic. Is it the brand, price or what?
How about Valvoline or Red Line syn?
:cool:
:) Dino oil from the beginning (Castrol GTX) Now its got 245,000 miles + No problems.
HATTRICK:)
'75 fj40 stock
'87 fj60 stock WT
'93 fzj80 hella / arb / kaymar > HIPPIE MOBILE. 245,000+mi.:cool:
