75 series - 80 series diff conversion (1 Viewer)
melbourne victoria
Hi Guys, I’m new to this didn’t even know these forums still existed.
I’m looking for information on 80 series diff conversions. I’m planning on doing it on my 75 series. I noticed a guy called VKYOOT on this forum did it if he’s still around to help out.
Thanks heaps,
Raf
Might be easier if you can find the front axle etc. From a HZJ or HDJ79 - from a width perspective
VKYOOT
33 · From Victoria, Australia
Joined May 27, 2008
Last seen Aug 14, 2015
Pretty easy, cut coil stuff off, weld on leaf perches. handbrake cable might be a fiddle, but probably not to hard to figure out. If you use a discs rear end, will need to swap to a disc disc master cylinder.
you know they are significantly wider than stock so you will need appropriately sized fender flares, of course you will need to modify either the 80 axles or modify the 75 suspension.
Do you reckon it’s better to go 79 axles over 80 for width. Reason I thought about 80 series axles is because everyone I’ve seen do it has used the 80 axle. Cheers for the response
VKYOOT
Joined May 27, 2008
Awesome! Great help. How did you work out thr measurements for the location of coil buckets and radius arm mounts etc. thanks heaps for the response
Hello , just wondering if you able to find details related to your question "How did you work out thr measurements for the location of coil buckets and radius arm mounts etc. thanks heaps for the response" appreciate if you can share the details
Trying to do mine and would be a great help
Full build pics in the thread “PZJ70 refresh rebuild”, I did the conversion a few years ago. @Loober has also done it and documented his work in his thread.
Cheers
