Can someone please help me ID these 2 connectors near fuse box under dash. 75 FJ40.
Thank you
Thank you
Makes sense for the round one. But the headlights work well so the square one is not to headlights. No reverse light though. And no guage light (but gauges work(Are they both for you headlight switch? The bulb(one with spring) would twist into the backside and the other would plug into the switch pigtail. When pulled out, the light bulb would illuminate the switch.
Are you saying there should be an emission box on firewall near fuse box under dash? Definitely not lights or signals as all of those work well. Even dimmer works.does the other go to some emission box? I see the one box on the firewall, but that has a different plug than lights.
I would have said the emission control box, but I see that there on the firewall. GW and GB are brake and turn signal wires...and WB is ground. Plug looks like a hazard plug, but have also seen that on emission components. Looking at Coolerman's diagrams closer I would say trailer socket plug - never seen that before. can you see the colors of the rest of the wires?Are you saying there should be an emission box on firewall near fuse box under dash? Definitely not lights or signals as all of those work well. Even dimmer works.
Yes 7 wires. Here is a better picture.. so this is open connector and goes to nothing? Ah I see now. It say "inspection connector". So problem solved right?There is an open connector for an 'emission inspection' in the diagram, seven wires. I might have that connector tucked up higher, on mine, so it isn't visible?
