- Location
- United States
74 Toyota Landcruiser FJ-40 Parts Vehicle, White, no motor, trans, t-case in the vehicle (all parts are a 74 model except as noted, all prices OBO, prefer pick-up or you pay shipping) - $1400 for all except the last 3 bullets in bold, $1,900 for all including the last 3 bullets in bold
· Frame, tub, title, & leftovers ($450 depending on what’s left on it when sold)
· 77 2F distributor w/ JTO electronic ignition ($80)
· 77 2F w/ rod thru the block, good head, brackets, no distributor etc ($125 or $200 w/ electronic ignition distributor)
· 2F JTO High performance coil <5K miles ($30)
· 2 aftermarket headers good shape ($100 each)
· 2 good intakes ($50 each)
· Aftermarket exhaust for 2F FJ-40 from the header all the way thru the dual outlet flow master @ rear of the vehicle good condition <3 years old ($75)
· Weber progressive carb w/ adaptor plates & new air filter assembly, taken off running 2F Nov 6th 2009 good running condition ($150).
· Weber 38/38 taken off running vehicle ~2.5 years ago, not cleaned up, but have a new air cleaner assembly to go w/ it ($100)
· (4) 74 model FJ-40 factory steel wheels w/ BFG muds, %70 tread, one wheel w/ bent lip but holds air, good shape ($175)
· Power Brake Booster ($75)
· Manual Saginaw Steering conversion, joints, shafts, box, custom pillar block, steering column? ($90 – joints, shafts, pillar block, column, etc. could be used on a power steering conversion)
· Front doors good shape w/ glass ($100 each or $175 both)
· Top w/ lift gate some rust but easily repairable, all glass good, no bottom barn doors or front doors ($250 or $375 w/ front doors)
· Drivers fender good shape ($75)
· Passenger fender small dent easily repaired ($50)
· Drivers & passenger side fender aprons good shape ($30 each)
· Hood good shape ($90)
· Bib good shape & Bezel with rust but repairable ($75 for both)
· Windshield frame, wiper motor, wipers, complete ($100)
· Front & rear seats w/ brackets, rough ($50)
· Front end drum brakes w/ factory springs complete ($75)
· Drive shafts front & rear from 79 FJ-40 and rear for 74 FJ-40 ($40 each)
· Front full roll cage w/ factory roll bar ($125, may keep)
· Dash, gauges, switches (let me know what you need & what your willing to give for it and I’ll decide if its worth pulling off)
· 79 model 4 speed Trans & t-case w/ shifters ($325, may keep)
· 74 model 4 speed Trans & t-case w/ shifters ($325, may keep)
· Rear end w/ factory springs, <1000 miles since internal rebuild ($175, may keep)
· (4) 31" BFG's All Terrains on chrome 15” FJ-60 wheels, with center caps & hub openings, all ~60+% tread, no spare ($350, may keep)
All prices OBO, let me know what else you may need off the vehicle… Thanks, Brandon <>< bwlemarr at bechtel dot com
