greetings and thanks for any help. 73 fj40
bought 73 fj40 and wipers did not work, cleaned out and re-greased as well as cleaned up motor and now working fine except for two things - making a bumping noise about as loud as someone snapping their finger kind of loud as it goes from one end of the arc to the other . in other words when it reaches the end of the arc - bump - then other side of arc bump - is this sound normal for a 73 windshied motor?
second issue is that wipers dont always go to the same spot at end of arc - maybe an inch off once in a while - assume thats not normal - does it seem I have something too tight or not put back right or again are both of these normal for a 73 windshied motor.
again, thanks for any help
