My new-to-me '73 with F engine Aisan carb (Pertronix Ignition) is not running like it should. I have a delay in acceleration when I step on the accelerator pedal, it especially worse from a cold start up. In fact it wants to stall when I go to take off. Under WOT I get serious sputtering or what sounds like spark knock with very little power.
I've searched and read many posts on here to help steer me down the right path. Here's what I've done so far:
1. I pulled the air cleaner assembly off and placed cardboard over the inlet while running. It died immediately, so I'm assuming I don't have any vacuum leaks. Is this a safe assumption?
2. I checked idle vacuum and found it to be around 15.5 in Hg.
3. The fuel bowl is at the set point, although I haven't looked at it immediately after the sputtering/flat spot.
Overall it seems to idle fine, audibly it seems rather low in fact. I need to get a tach to determine where I'm at. The problem kicks in when I go from no throttle to throttle and under load I get the sputtering/spark knock with very little power.
I assume that I'm running lean, but being a newb to carburetors I'm a bit lost. In fact, I thought I was adjusting the idle speed and it turns out I was adjusting the throttle adjusting screw? I know, I know. I'm reading the FSM and I still cannot figure out where the idle speed screw is?
Please help!
Here are some pics -
I was adjuting the lower left screw - oops (I'm guessing this is choke/high idle?). Is the idle speed screw the lower screw to the right in this picture?
Please help!
